This is what I get every time I open SolidWorks student edition. "Failed to enter registry try Regen". Why does that happen? Anybody
Has this student version worked for you before the error started to appear?
It would seem that SolidWorks is trying to access data from the computer registry and is experiencing a problem. Try un-installing the software and then re-install using the proper activation and key codes.
Hope this helps...PLCamp
To answer that, yes it was, working well. I solved that issue by having to re format my operating system. I don't rightly know how but I don't get the message anymore. Thanks for you answer.
