587,739 active members*
3,186 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Reference buttons dont work path pilot 1100 ser3
Results 1 to 2 of 2
Hybrid View
    Oct 2006
    71
    I just picked up an 1100 series 3 mill. I power up path pilot, undo estop then power on machine, then hit reset. When I press the ref buttons nothing happens. I can power off the machine, etc reset the control move the machine manually to the limit switches using the status Limit leds then hit ref which would work I suppose, but the machine does not do this automatically. None of the limit switches are stuck.
    Is it normal to reference these machines manually to the limit like this? It looks like they should do this automatically from reading the manual but maybe poorly written?
    Is there a global setting that stops automatic referencing? I searched online and didn't see anything.
    Oct 2006
    71
    Re: Reference buttons dont work path pilot 1100 ser3
    For some reason, the control defaulted to having the LIMIT SWITCH setting not checked in settings. Now works normally.
  1. Update MOBO that work with Path Pilot and Linux?
    By Djstorm100 in forum Tormach PathPilot™
    Last Post: 12-19-2017, 01:41 AM
  2. Got my Path Pilot
    By BIG IGG in forum Tormach PathPilot™
    Last Post: 02-10-2016, 03:06 PM
  3. Tormach 1100 seriers 3 running Path Pilot X Axis jammed up.
    By kenny calman in forum Tormach Personal CNC Mill
    Last Post: 10-17-2015, 07:49 PM
  4. Subroutines with Path Pilot
    By dbren in forum Tormach PathPilot™
    Last Post: 07-27-2015, 04:31 PM
  5. Fanuc OT Buttons dont work
    By flannman in forum Fanuc
    Last Post: 11-27-2007, 02:40 AM
