587,188 active members*
3,519 visitors online*
Results 1 to 5 of 5
    Jun 2011
    9
    Question Red n Black Chinese 100W laser - Pulse function
    On one of my lasers the pulse function has stopped working - I press the button on the control panel - I get the beep - but no pulse fireing from the laser!! Weird!
    Everything else working as normal!
    Need to fix it as it makes routine post cleaning/maintenance alignment pretty impossible!!
    Anybody have any ideas?
    Andy
    Oct 2015
    96
    Re: Red n Black Chinese 100W laser - Pulse function
    Check if you have no mess-up in control panel (say - extra short time/power etc.)
    Polish @ Éire
    Dec 2006
    124
    Sometimes, though quite infrequent, the firmware in the onboard electronics gets corrupted, so try downloading the firmware again to the laser machine.
    Jan 2008
    940
    On mine you can set the pulse power and if it is to low it will not fire
    Jun 2011
    9
    Hi
    Thanks for the heads up - where is the setting please?
    Andy
  1. 100w chinese laser issues
    By Chrissto007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-15-2017, 06:18 AM
  2. Chinese 100W laser (Red)
    By andygp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-03-2017, 01:25 AM
  3. Chinese laser 100W doesn't fire after replacing a Leetro controller
    By Aquacut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2016, 08:31 AM
  4. Need advice on chinese machine (100W) - safest settings
    By comrade in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2015, 09:54 AM
  5. About Chinese 100W Laser Engraver
    By graphpix in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-03-2008, 12:33 AM
