Getting my ducks in a row while my finances are aligning themselves. One more week and I should by ready to drop the hammer.
My goal is prototyping and light production of aluminum, plastic, steel and stainless (303ish)
I have experience with them all in a manual lathe so shouldn't be such a big learning curve.
I will work towards making a bar feeder, even if it's only a few feet of material, to speed up production runs.
Final goal is PCNC 1100, SlantPRO, good drill press or maybe mill/drill as well as my laser cutter and a small CNC Router to flesh out my mini workshop (two car garage)
Existing equipment is CNC Taig mill, Taig lathe, Jet 9x20 lathe and various odds and ends. (grinders, polishers, belt sander etc..)
Just going over the site I chose this lineup.
34444-T - 15L Slant-PRO™ CNC Lathe with Turret
Lathe Turret: 33273 - Turret Kit for Tormach 15L Slant-PRO
Lathe Controller: 34388 - Lathe Controller
15L Slant-PRO Oiler: 31374 - Automatic Oiler (230V)
Lathe Enclosure: 34713-T - Full Enclosure Kit for 15L Slant-PRO
Additional Lathe Options: 33269 - Lifting Kit for Tormach 15L Slant-PRO, 34381 - Extended Warrranty for 15L Slant-PRO
Owner's Kit: 34398 - 15L Slant-PRO™ Owner's Kit
$17,162.50
33156 - 3-Jaw Reversible 6" Lathe Chuck (D1 Type Direct Mount) $276.25
34902 - 6" Aluminum Soft Top Jaws (2" Tall) $34.80
34903 - 6" Aluminum Soft Top Jaws (3" Tall) $44.70
33283 - 5C Collet Closer (Lever-Action) $985.00
34727 - 5C Round Collet Set (35 Pcs.) $235.00
34799 - Metric 5C Round Collet Set (9 Pcs.) $99.50
34798 - Metric 5C Round Collet Set (13 Pcs.) $99.50
34105 - MT-3 Live Center $28.95
33336 - 4-Jaw Independent Reversible 6" Lathe Chuck (D1 Type Direct Mount) $239.50
Questions:
1. Is the three jaw a good one? Better off getting a Bison? (I want precision)
2. Same question about the 4 jaw?
3. Has anyone fitted a bar feeder? Ideas?
4. Tormach tool holder recommendation?
5. Any use for the QCTP if I'm getting the turrent?
6. In the video it sounds as if the spindle RPM's are going up and down. Is this a constant surface feed / minute feature?
7. How much does the turret reduce carriage travel?
8. Can a pendent like the VistaCNC P4-S be used?
Welcome any more words of wisdom, hints, tips or tricks.
Thanks for looking
