587,149 active members*
5,173 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Re-installing crusty old Deublin rotary union?
Results 1 to 7 of 7
    Oct 2012
    53
    Hello again everyone,
    My machine "has" TSC and came with a crusty un-installed Deublin rotary union. It spins freely but I am skeptical of the condition of the seals due to the fact that it is no longer installed. I would like to re-install it to use the spindle air blast, at least. What is the worst-case scenario if the seals are bad and I try to run through-spindle coolant? Is the spindle cartridge water-tight from the top? Or will I bathe my spindle bearings in coolant?
    I found the edge protector and plate I need on the MAG site, but I sure won't be shelling out $750-$1,500 for another Deublin any time soon.
    Dec 2006
    585
    Re: Re-installing crusty old Deublin rotary union?
    What is the model of the machine and what year is it???
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2012
    53
    1999 Arrow 1000
    Feb 2005
    117
    what is the size of the rotary union on your machine. Also have you thought
    about rebuilding the rotary union .
    Deublin does not make the ceramic seals or bearings,
    Oct 2012
    53
    Johnd,
    I believe the one that i have is this one https://www.deublin.com/Products/1109-053-188 , but I will have to verify. I have thought about rebuilding! I called Deublin to get a quote on a rebuild and they said my model was not serviceable. I have rebuilt turbos before and it seems like it should be the same sort of process.
    Dec 2006
    585
    If you would not use coolant through the spindle, I would not install the union. If the union leaks the coolant goes down in the tool un-clamp section and causes problems. The coolant would also get on the spindle belt. Why take the risk.
    Oct 2012
    53
    Mike,
    Makes sense! I don't want that one bit! I might hijack the TSC coolant valve solenoid and use the M27 to run through spindle air instead. I can cap the TSC feed just for extra safety.
  1. Vari-Grip collet closer rotary union
    By OT-CNC in forum Hardinge Lathes
    Last Post: 01-24-2023, 05:12 PM
  2. Problems on installing rotary encoder on Gecko G540
    By Rimbaldo in forum Gecko Drives
    Last Post: 05-24-2020, 03:56 PM
  3. Solid union
    By Melkiades in forum Rhino 3D
    Last Post: 04-15-2017, 12:50 PM
  4. Rotary Union for Pneumatic Gripper Drive
    By simplesimon in forum Linear and Rotary Motion
    Last Post: 01-09-2017, 08:44 PM
  5. johnford deublin
    By Damnifiknow in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2012, 06:30 PM
