Hi everyone..I am playing with the evaluation version to be used on the plasma cutting table that I am building..I set up the plasma tool to have a feed rate of 25 ipm..but my table will have a rapid speed of 50 ipm..Looking at the g code generated,it has a cut speed of 25 like it should but there is no change to make it rapid to 50ipm over to the beginning of the next cut..thru out the complete G code it stays at 25 ipm..Did I miss something in the initial setup or does it not have this feature to set rapid speeds..I am using Mach 2 plasma pause for the post processer..Mike
