587,798 active members*
3,223 visitors online*
    Jul 2007
    4
    R2E4 won't boot
    I am trying to get a Boss 9 working for a friend, it was purchased for $1000.00 condition unknown. I have never operated one newer than a boss 4 so not sure what to expect as far a boot sequence. This one has nothing at all on the CRT unless you press the reset button on the side of the cabinet. At that point it says "Hardware test in progress IDE1" then it starts displaying a list of tests that all end with ok except for the last one: INTS then thats all it does. All the leds are lit on the control panel but pressing buttons or even hitting the emergency stop button doesn't do anything. The logic power supply had failed so I replaced it with one from a pc and the voltages are +5, +12, -10 not perfect but close. 2 of the axis are on the limit switches. Can anyone tell me what to look for or what possibly could be happening? Here is a screen shot http://www.overbeckmachine.com/images/boss9.jpg
    Thanks in advance
    Wayne
    Nov 2004
    3028
    There is a trouble shooting section in the maintenance manual. I hope you have one. It takes you step by step for every voltage and what the range is. Is this on a phase converter?
    There are a pile of LED lights to aid diagnosis. The FMDC has eight accross the top. The AUF has one just about dead center and the mother board (BSP) has a string of them along the edge facing out. Again, the book would help.
    It sounds as if the EZIO is bit maping the CRT correctly and the BSP is not booting correctly. All those tests are normal, but it does not go on from there.
    George
    Jul 2007
    4
    R2E4 won't boot
    Thank you for the help, I have nothing but 4 schematics, I am on the lookout for service and operation manuals. I am running it on 208 3 phase. Any ideas appreciated, for now I think I will reseat the chips and the boards and double check fuses per suggestions on other similar machines. Any one have the troubleshooting info in pdf, jpg, or faxible format?? I'm reaching but my fax number is 831-423-9363
    Thanks again Wayne
  1. MB1 won't boot
    By daveelc in forum HURCO
    Last Post: 04-20-2007, 02:32 AM
  2. 2006 TM-1 won't boot up!
    By Edster in forum Haas Mills
    Last Post: 12-07-2006, 02:12 AM
  3. multi-boot two HDs
    By Karl_T in forum Computers / Desktops / Networking
    Last Post: 06-21-2005, 05:58 AM
  4. No boot on EZ-Mill DX2 BPT
    By mmm2003 in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2005, 04:28 PM
  5. boot disk
    By spuzzbutt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2004, 02:39 PM
