I have been reading quite a bit lately and have some questions.
1. What size of CNC machine would you switch to a dual x-axis motor system?
2. Does the center of gravity matter on the z-axis?
3. should I build 2 CNC machines (one for circuit boards and one for larger projects)?
4. Is there certain steppers/servos to avoid and controllers?
5. What is the advantage of using a gear box vs. direct drive?
6. Is MDF better than Polyolefin material (what they make plastic cutting boards out of).
Thanks in advance
James
