587,216 active members*
2,991 visitors online*
Results 1 to 10 of 10
    Nov 2009
    4
    Question about Keling Spindles
    This might be a dumb Question but on the KL-2200 Milling Spindle. Do you need an external Pump for the water cooling or is this built into the spindle.
    Does this Spindle include a spanner/Wrench and any collets... The website is very vague on info makes me nervous wanting to buy these items from them.
    Or its just my complete ignorance.
    :withstupi
    Jul 2007
    1602
    You need an external pump. Some people are using aquarium or other similar small pumps.
    Do a forum search on "chinese spindles" and you will find quite a bit of information.
    Also see the video on the first post in this thread. He is using a cpu cooler radiator to cool the spindle: http://www.cnczone.com/forums/showthread.php?t=78742
    35538
    If you buy direct from China, you can get it for less than half the Keling price.
    http://cgi.ebay.com/2-2KW-WATER-COOL...item5ad5cd5d57
    I think they come with one collet and one nut, but I'm not sure. Don't know about a wrench, either.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2009
    18
    Smile
    It's interesting!
    [QUOTE=ger21;707510]If you buy direct from China, you can get it for less than half the Keling price.
    Quality, Support, Warrenty will make the price different
    Pls check here or email to me at [email protected]
    http://www.kelinginc.net/CNCSpindleandController.html
    Apr 2009
    78
    What type of pneumatic valving is required when using the tool changer on these spindles?
    Jul 2007
    1602
    Quote Originally Posted by palenn View Post
    Just so the there is no confusion, the spindles under discussion are the ER collet spindles not the tool change spindles.
    I imagine the tool change spindles operate on about 90 psi so any manual or solenoid operated pneumatic valve with the appropriate rating should work.
    bob
    35538
    Yes, when you buy from Keling, if you have a problem, you won't have to ship it back to China and wait for a replacement.
    Gerry
    Jul 2009
    11
    lmao boy that was quick any way just get one from china I did no problems and the ones i dealt with are very friendly even covered half the cost on transfer fee's of cores if you use paypal you don't have to worry about that there better then you would expect them to be there quite and run very smooth here
    http://cgi.ebay.com/WATER-COOLE-MOTO...t_12082wt_1165
    half the price you will spend at keling if not less of cores you might want to try there best offer listing they normally will take $60 lass then the listing I sent here
    they don't come with the wrench you can use your every day open end wrenches so it's kinda pointless to send you one with it and of cores it comes with one collet so you will have to get a set you can just use a water cooling system for a gaming computer to cool the motor
    you just get the vfd and the motor after you have the vfd just buy the spindles if you are running more then one machine or spindles on a single machine just hook up a couple toggle switches to switch from one to the other ($5.00 vs $250 savings)
    of cores steppers drives power-sp breakout boards your really not going to do better just go to keling for all that
    Jul 2009
    11
    Quote Originally Posted by 3dsignco View Post
    :withstupi
    just one collet no wrench (not required just use your every day open end wrenches) and go buy a set of collets you will need them.
    no pump you will need an external one plus heat exchanger and lines+reservoir you can get a liquid cooling kit for a computer for under a $100 and they work just fine with these spindles and should have every thing you need to cool it
  1. Keling Nema 23 3 axis pack question
    By absolutepoker01 in forum Automation Technology Products
    Last Post: 11-10-2009, 01:22 AM
  2. Keling Steppers, Controlers and a BOB question
    By 2_many_hobbies in forum Benchtop Machines
    Last Post: 04-07-2009, 02:03 AM
  3. Newbie question- Why fast spindles in Al?
    By Shepard in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2009, 09:03 PM
  4. Question about Lathe/Milling Spindles
    By jho5820705 in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2009, 08:35 PM
