587,426 active members*
4,373 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Purchasing Drill Bits for Tormach 770
    Sep 2012
    0
    Hi everyone, I am super new to using forums and even more of a noob at using the Tormach 770 pcnc purchased by my university. I have been tasked to get this machine up and running but being unfamiliar the device, I am not even sure where to start on purchasing drill bits for the machine. I was hoping to get some advice on some initial purchases focusing primarily on the type of collets or drill bits I may need. This machine will be used for reductive prototyping for a senior design class, mostly dealing in plastics, delrin, acrylic, uhmwp, etc. Can anyone suggest some basic drill bits and where I could purchase them from just as a start-up? Any advice would be helpful.
    Re: Purchasing Drill Bits for Tormach 770
    Hi I got a 770 this year and I use the TTS ER20 toolholders for drill bits to minimize the runout compared to the drill chuck style ones. Drill chucks will probably work OK too except for smaller drill bits (under 1/8").
    Most jobs I just order individual drill bits in the right sizes off McMaster. Getting any kind of HSS/Cobalt TiN coated drill bit set would be a good start but they'll be breaking and dulling, and the individual sizes are so cheap even on McMaster
    Get yourself a nice spotting drill too, this can help with drill wandering, I use a 1/4" carbide 140° for many jobs
    Finally the 770 really does not like to spin the larger drill bits (1/4"+), I get them stuck in aluminum a lot using conservative speeds and feeds when my belt is in the high RPM position. I'd suggest if drilling bigger holes use the low RPM belt position to get better torque
    Wow this was 6 years old? My bad!
  1. Purchasing larger qtys of screwdriver bits
    By ingear in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-19-2013, 11:37 AM
  2. Need Help to I.D. Mill/Drill - Purchasing Advice - I.T.C.
    By lewdfinger in forum Benchtop Machines
    Last Post: 01-14-2009, 09:15 PM
  3. Need Advice purchasing cnc mill.. syil X3 or tormach?
    By petecul in forum Benchtop Machines
    Last Post: 04-13-2007, 11:37 PM
  4. Have you ever seen these drill bits?
    By yohinan in forum MetalWork Discussion
    Last Post: 02-06-2007, 05:21 AM
  5. Drill Bits
    By dighsx in forum Community Club House
    Last Post: 01-24-2007, 08:06 AM
