587,744 active members*
2,977 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 2500SY turret/spindle mode problems
Results 1 to 4 of 4
    Oct 2012
    8
    Question Puma 2500SY turret/spindle mode problems
    I have a Puma 2500SY that will not change tools on the turret, spin the live tooling or come out of c axis mode and switch to main spindle mode on the spindle mode select. There is no machine alarms or messages. Can anyone help?
    Oct 2012
    8
    Re: Puma 2500SY turret/spindle mode problems
    Now the machine has a 2047 alarm. "TURRET CLAMP SWITCH ALARM OR TURRET CONTROL UNIT ALARM"
    Oct 2012
    8
    There are no alarms on the turret drive unit and it looks like the switch is sensing the dog for the turret clamp. The switch lights are coming on and also the switch is showing on and off in the diagnosis screen. Not sure what else could be causing this alarm.
    Oct 2012
    8
    Now I feel like I'm talking to myself... In case anyone was keeping an eye on this. The problem is resolved. I'm not sure how or what was going on, but I ended up calling Doosan and having them walk me through. We went through a bunch of K, R and X numbers in the diagnostic screens. Turns out when I first called K15.6 was a 0. Witch indicates that the turret hasn't completed a turret index. He said that something didn't add up because every number we checked after that indicated that the turret index was complete (but still K15.6 was a 0). He asked if there was a light lit on the manual index button on the control. There is not lamp but I ended up hitting the button anyways. I saw the turret move a little so I pressed it again and the turret changed positions. Not sure what was holding it up, but it was back to normal now. (even K15.6 was switched to a 1). Kind of weird that nothing was sticking out that was wrong (other than K15.6 not being completed).
    Thanks,
    Tony
  1. PUMA 2000SY TURRET PROBLEMS
    By VALBYRNES in forum Daewoo/Doosan
    Last Post: 05-16-2014, 05:41 PM
  2. PUMA 2500SY Spindle Sync
    By LUX93 in forum Daewoo/Doosan
    Last Post: 02-27-2013, 12:04 PM
  3. Puma 2500sy XY Centerline
    Last Post: 10-02-2012, 02:42 PM
  4. Puma 2500SY YEAR 2002
    Last Post: 08-08-2012, 04:47 AM
  5. I Need A Feature Cam Post For Puma 2500sy
    By Phill Bovingdon in forum FeatureCAM CAD/CAM
    Last Post: 06-15-2007, 10:56 AM
