Originally Posted by
SCzEngrgGroup
You seem to like speculating on things with which you have no experience....
A 6mm collet will hold a 1/4" tool with no problems whatsoever. Metric ER collets have a usable range of +/-0.5mm. I use ER collets almost exclusively, most of the ones I own are metric, and I have NEVER had a tool come loose from an ER holder.
Also, with adequate drawbar tension, coolant on the TTS shank is a total non-issue. Mine very often come off the machine with the shanks dripping coolant, and it has never caused a problem.
As for the LDB - there have been several design revisions during its production life. I would expect current production LDBs to be better than earlier ones due to these improvements. Personally, I'm not convinced any practical Belleville-based drawbar will provide fool-proof tool retention.
Sometime, hopefully early next year, my PDB will be available for the Pulsar, and will provide the same tool retention as it does on the Torus Pro.
Regards,
Ray L.
