587,920 active members*
3,497 visitors online*
    Mar 2007
    23
    Problems with soft aluminum
    Hi!
    I have huge problem with milling soft aluminum. Im not sure what alloy it is exactly but it is very soft and gummy. Guy who sold this material told that it is grade that is not supposed to be machined.
    Current cutting parametres:
    Feed: 3000m/min
    RPM: 12000rpm
    DOC: 2mm
    Passes: 3
    I need to cut several hundreds pieces made from this stuff. Im using GARR 2-flute 10mm solid carbide endmill and flood coolant. 2mm DOC is absolute max with this setup. Any deeper and aluminum just melts rather than cuts. It takes ages with 2mm DOC. With harder alloys i can easily get 6mm DOC per pass or even more. Coolant spray is pointed right where carbide meets aluminum.
    Is there some way (maybe other type endmill) to make deeper cuts?
    Jul 2005
    12177
    Are you using the high helix two flute cutters from GARR? I think the code is 242M, they have a 45degree helix. We machine a T0 aluminum alloy and find these are the best cutter for clearing the chip out.
    I had described our conditions in this thread:
    http://www.cnczone.com/forums/showthread.php?t=60698
    I would also use a larger diameter cutter if possible, something like 15mm to give more room for chips.
    Oct 2008
    7
    don't know the outer dia. you talking about. for alu, can use indexable cutter, only changing carbide inserts. give u a website to look at.
    www.cutting-tools.com.tw
  1. SOFT OVERTRAVEL
    By metx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2007, 06:06 AM
  2. Replies: 2
    Last Post: 08-30-2006, 11:08 AM
  3. Machining thin wall soft aluminum
    By TurboME in forum MetalWork Discussion
    Last Post: 03-01-2006, 03:11 PM
  4. I have the driver, but, i need an other soft
    By NCN in forum DIY CNC Router Table Machines
    Last Post: 02-02-2006, 09:22 PM
