587,495 active members*
3,497 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Problems in autocad 2000 with DXF
Results 1 to 11 of 11
    May 2004
    83
    I have Autocad 2000 also 14, Mach3cnc, Lazycam, and D2cn,
    I have had this problem for ages now,
    When I do a drawing and convert to DXF I do a pedit before loading into lazycam, I always seem to have grey broken lines all over the blue screen this happens a lot and is very time consuming, (annoying), I think its hidden dots or breaks,
    My question is what can I do to remove these hidden things before loading up in lazycam?,, even when I clean and optimise in lazycam there are still a whole bunch of grey broken lines I have the same problem if I use D2cn,
    I know the problem is me,
    ...........Edmund........
    Edmund
    Nov 2008
    12
    Check and try
    Hi
    I think you draw 3D model and this model is not clean. I mean you make many modification on this model and software confuse to convert. Not too much modify and try to draw only from parents-sketch. Check 2D sketch and use some command like (audit, overkill, purge).:cheers:
    35538
    post a .dxf with the problem.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2004
    83
    Problems in Autocad 2000 with DXF
    Hello Ger,
    hopefully the attachment will arrive,
    Attached Files Attached Files
    Edmund
    May 2004
    83
    Problem with cad 2000 and DXF
    HA THA
    Thank you for your reply I will give your suggestion a try,
    Thank you........Edmund......
    Edmund
    35538
    You have a lot of extra lines under the outside border, and one extra arc under the inside border.
    Also, you shouldn't need both the point in the center of the holes as well as the circles for the holes. One or the other should be all you need, depending on the CAM program you're using. Try this one.
    Gerry
    May 2004
    83
    Ger21,
    I have just tried that attachment in my D2cn program, I was able to run it in Mach3 ok, can you explain how you managed to eliminate all the problem lines?, I have always been plagued with them, I've had very few times when I have loaded a dxf into lazycam or D2cn and they have been ok first time, Is there another opp in autocad other than pedit where I can be sure that it will work first time?,
    Thank you for your help,........Edmund..........
    Edmund
    May 2004
    83
    HAH THA
    I did try a purge in the dxf, not sure if I did it right but nothing seemed to change, I will try the other two suggestions and see if that helps,
    Thanks for your interest......Edmund....
    Edmund
    35538
    Once the outside is joined into a closed shape, drag a box over portions of it (from left to right) and the smaller segments should get selected, so you can delete them.
    Gerry
    May 2004
    83
    ger21,
    thank you, I have learnt something new today, didn't know about left to right, well I guess I new, but never used it, always did right to left, so thanks,
    now perhaps my drawings will improve,
    ger21, Ive always remembered I got the pedit from you many moons ago, thanks for that too,
    Edmund
    35538
    Right to left selects whatever the box touches. Left to right selects only what's in the box.
    Gerry
  1. Autocad 2000 Move
    By N4NV in forum Autodesk
    Last Post: 03-23-2014, 03:30 AM
  2. Help: Autocad 2000 (Autocad Error aborting)
    By Holmes_ca in forum Autodesk
    Last Post: 05-07-2010, 02:07 PM
  3. AutoCAD 2000 to AutoCAD LT 2010?
    By 2kjettaguy in forum Autodesk
    Last Post: 08-15-2009, 03:33 PM
  4. Importing 3D from AutoCAD 2000
    By noisillator in forum Uncategorised CAM Discussion
    Last Post: 06-19-2009, 03:44 AM
  5. AutoCad 2000 DXF Question
    Last Post: 01-20-2005, 12:50 AM
