Hi all,
I'm using Cambam software as CAD2CAM convertor. Everything was looking fine until I was started to cut, then I realized that the milling direction is incorrect. I get lots of problem at the edges when the milling direction is CCW.
I didn't find how to change the milling direction. I attached image which shows the problem, part of the milling is clockwise and part is counter clockwise. I wish do define that the direction will be only CW. Does anyone know how to define it in Cambam or may be help me solve the problem.
BTW I can't contor the router spin direction.
Thanks in advance
Amir
