587,499 active members*
4,792 visitors online*
Thread: problem
Results 1 to 15 of 15
    Nov 2013
    13
    Question problem
    E09-001C E09-001C
    CHARACTER RAM OK
    FIFO READY
    WORK RAM OK
    when turn on the machine that we appear on the screen does anyone know what is the word ? you might ask for help
    Nov 2013
    13
    Re: problem
    machine is Fanuc tape cut W2 wire 1988
    Aug 2011
    2517
    Re: problem
    those messages don't look like Fanuc
    which control do you have?
    Oct 2014
    137
    Re: problem
    This message speaks of that passes test of the colour monitor which has its CPU, memory, FIFO, e.t.c.
    The Message has a green colour.
    If on this test is stop then may be is not started CNC system CPU or is breakaway of cable the CNC<->monitor.
    Nov 2013
    13
    Re: problem
    Fanuc-Japan
    CNC tape cut W2 1988 god
    Nov 2013
    13
    Re: problem
    kad se upali masina samo ovo stoji na monitoru kao na slici.
    da li je moguce da je do kabla koji povezuje cnc --- monitor ??
    Nov 2013
    13
    Re: problem
    when it comes on just this machine stands on the monitor as shown.
    is it possible that it is up to the cable that connects the monitor cnc --- ??
    Nov 2013
    13
    Re: problem
    Do you know who performs repair motherboard and price ?
    Oct 2014
    137
    Re: problem
    Please, tell me your PM.
    What type Mother Board have you?
    Nov 2013
    13
    Re: problem
    ovo mi je maticna ploca evo serijski broj Attachment 272494
    Apr 2009
    1379
    Re: problem
    That is a 0-B motherboard; there are several other versions (-0285, 0286) which have slightly different configurations.
    What country are you in?
    Nov 2013
    13
    Quote Originally Posted by memoryman View Post
    Bosnia and Herzegovina
    Bugojno 70230
    Apr 2009
    1379
    Re: problem
    I don't know how difficult it is to get any service in your country; once you are sure that the motherboard is the problem, it may be cheapest to get it exchanged .
    Mar 2007
    23
    Re: problem
    Hi Arminmen, finally how did you solve the problem ? I'm having the same problem on Tape Cut W0 with Fanuc 0 B.
    Jan 2018
    1
    Hi I'm having the problem on Tape Cut W2 with Fanuc 0 B.
    E09-001C E09-001C
    CHARACTER RAM OK
    FIFO READY
    WORK RAM OK
  1. Having problem with CNC driver/card problem
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 04-09-2014, 05:45 PM
  2. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  5. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
