587,132 active members*
3,017 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Preloading of ballscrews without thread
    Apr 2010
    64
    Hello,
    I was looking for advice on how to preload ballscrews that dont have a threaded end on them? I was told by several sources that it can be done however I am failing to find good reference material on the site about how to do it exactly. My ballscrews are hardened so machining them on my lathe isnt really a viable options, and grinding threads in them is expensive. Any advice would be greatly appreciated. Thanks in advance.
    PS
    these are going into a custom sherline 5000 mill conversion that I am doing so the preload need to be a lot.
    use shims to push the screw in one direction against a bearing surface
    May 2013
    480
    Re: Preloading of ballscrews without thread
    Only the surface is hardened, grind it off in a lathe and then cut threads. you can also anneal the end with a blowtorch.
  1. Taper Roller Bearing Preloading
    By aagoyle1 in forum Linear and Rotary Motion
    Last Post: 03-19-2010, 11:57 PM
  2. Installing and Preloading Ballscrew??
    By iaknown in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2009, 04:11 PM
  3. Installing and Preloading Ballscrew???
    By iaknown in forum Linear and Rotary Motion
    Last Post: 10-03-2009, 03:25 AM
  4. Preloading
    By haku in forum DIY CNC Router Table Machines
    Last Post: 03-13-2008, 10:03 PM
  5. Preloading ball screws.
    By eman5oh in forum Linear and Rotary Motion
    Last Post: 01-14-2006, 04:10 AM
