The program works and I finished my first project on BobCAD-CAM using Mill2 Axis function...but another problem went on; I tried to test the code using “Verify” function on Milling Stock window but the verify window went on and I wasn’t able to start the program. I decided to use Predator Editor via Modules menu and “Edit CNC” command.
The program started but I wasn’t able to find the button for start the simulation also from the “File menu” as described on the “help”. I saved the Post file and changed the line (SBOX XO………) into (SSTL PART…….) as described on page 61 of the training lessons with no positive results. I tried again clicking on the “Posting” field using “Edit CNC “ command..! I used the saved G code post on testing function on Mach3 program with an excellent result.
Please let me know where I’m wrong and where is possible to find more information on “Predator” Best regards
