587,853 active members*
3,584 visitors online*
Results 1 to 5 of 5
    Jul 2014
    3
    Predator Editor TNc 155 Data transfer
    MOving to a new pc with win7. Need to be able to transfer files to TNC155 controller on a Huron Mill.
    I am a SmartCam user none the less Predator Editor was recommended.
    Not sure what to enter when setting up.
    Any and all insight would be of great help.
    Jun 2004
    511
    Re: Predator Editor TNc 155 Data transfer
    Before you move to the new PC, check the settings on the old one.
    Jul 2014
    3
    Quote Originally Posted by ifixcnc View Post
    The pgm that I was using to transfer files does NOT work with win 7.
    Port Com1
    Baud rate 2400
    Parity Even
    Data Bits 7
    Stop Bits 1
    Time Out After Linefeed 0
    Time Out Delay 2
    Initial D/L Time Out 0
    End of Block Character M J
    X on Char Q
    X off Char S
    Code Type ASCII
    Jun 2004
    511
    I understand that you have to use another program but, the settings on the machine side will be the same. Just set the new program to the old settings.
    Jul 2004
    173
    You can use Predator and it will work with Windows 7 or 8. You might be hard to find a serial port on a new PC running Windows 7 or 8, so make sure you find the proper hardware.
    USB or Ethernet to Serial devices work with the Heidenhain.
    Set the machine parameters as noted, set Predator Editor as the same and send from the CNC back to the CNC Editor. Check to make sure the file is in tack and everything there. If not, check the drivers on the serial hardware as they generally are the problem.
    If you get stuck, give me a ring.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
  1. Where is the licensing for Predator Editor at?
    By Stampede in forum BobCad-Cam
    Last Post: 10-12-2015, 03:15 AM
  2. Bob Cad & Predator editor
    By Robert Szweda in forum BobCad-Cam
    Last Post: 07-23-2011, 08:53 PM
  3. Predator CNC Editor - Backplot
    By aussiegazza in forum BobCad-Cam
    Last Post: 06-30-2011, 08:08 AM
  4. Predator Editor Back Plot
    By rwestbr in forum BobCad-Cam
    Last Post: 08-13-2009, 07:49 PM
  5. Predator Editor problems
    By tntmfg in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2009, 06:24 PM
