hello we buy predator v8 and I want to know when we Loade (big file)
Can your star on a line of my choice ex; ( n65 ,,,,,)
in remote start how to do roll a continuous file forme the dnc to the cnc
andre
andre
I believe you'll need to add a Restart Link to the top of your Send command. Once you do this, you can click on Help to see what options exist.
If the sofware has the configuration to doit, you have to use similar call out command to use to send and receive programs example
(LD)(F8)(5088) is the standard comand you use to call a program from the server to the machine
to start specific line program you have to use
(RESTART)(F8)(5050)(N65)
F8=FILE LOCATION
5050 PROGRAM NUMBER
N65 LINE TO START
You have to punch the 7777 or the program you name with this command
O7777
M30
Then turn the key to dnc control option
and press the soft key star
Hello,
I see that you know the program Predator DNC very well. I have Version 8 of this program.
The work which i must do is very simple. I have to Machine a large piece, and the result file is huge and this is why I must restart the program on line (ex: N50...) often. Any ideas are welcome. How do we receive from CNC mahcine the control is a Fanuc 18M machine and what are the good setting so the Fanuc 18M and the Predaot DNC....
Thank you
