587,794 active members*
3,008 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > PRECISE Electric Hi Speed Jig Grinding Attachment
Results 1 to 2 of 2
    Aug 2011
    41
    Hi all,
    I just picked up a electric precise jig grinder attachment/hi speed spindle for the mill etc.
    I'm sure I will have many questions about this unit, but first off I need to get it running.
    I read some of them use a normal 110V plug , this one doesn't.
    It uses a round plug, I've seen these used to connect hi speed spindles to VFD's,
    does anyone know of the VFD that these require? I see some chinese ones on ebay
    for sale and would like to know if they would work? I haven't received the grinder
    yet, so I don't have the electrical specs.
    I would like to hear any comments as well of fellow users of these precise spindles for
    micro milling and drilling (like max tool size), that is what I plan to use this for along with grinding
    occasionally. I wouldn't expect you would want to go over .0625" for milling or drilling, but I don't
    know, that's why I ask. It would be nice to know if it's capable of .005" to .125" end mill dia. range.
    Thank you all for any interest,
    Jim
    Aug 2011
    41
    Re: PRECISE Electric Hi Speed Jig Grinding Attachment
    Ok so I just got the specs on this spindle and really would appreciate any help on finding a VFD or whatever it is I need to control this spindle.
    I am not to electrically inclined...
    Serial # SC57 Precise Jig Grinder
    RPM 15,000-54,000
    Power - 0.7Kw
    Amps - 3.5 Amp
    Hz 250-900
    Volts 45-165
    Input power connector is a round plug with 4 pins, pins are in a half circle pattern.
    I don't have anymore info on this unit other then that, any and all help is appreciated.
  1. Fixture / Attachment for Grinding Wheel. What is it?
    By Dreeze in forum Mass finishing equipment/media/strategies
    Last Post: 01-30-2014, 10:57 PM
  2. Help with drill grinding attachment to Universal Grinder
    By simso in forum Toolgrinding / Toolgrinding Machines
    Last Post: 10-24-2011, 09:05 AM
  3. VTL retro fit Grinding attachment
    By 24kilo in forum Uncategorised MetalWorking Machines
    Last Post: 05-23-2009, 03:29 PM
  4. High speed grinding attachment
    By devincox in forum I.C. Engines
    Last Post: 10-02-2006, 09:42 PM
  5. Precise Radius Grinding?
    By Otokoyama in forum MetalWork Discussion
    Last Post: 03-06-2006, 12:45 AM
