Hi All,
I am in the planning stages of a CNC conversion using Gecko 320s and 30 Volt servos. The servos are rated at a maximum current of 24 amps, this is a lathe so there will be two servos.
I have read through the various posts on this subject and looked over many of the submitted schematics of similar designs. I have noticed that most, if not all of the transformers shown, are rated at 10 amps or so.
I do not know enough about electronics to understand this so I figure I had better ask...
If I have 2 servos rated at 24 amps ( or more importantly, 2 geckos that can handle 20 amps), shouldn't the transformer be able to handle 20 amps?
Chris
