587,752 active members*
4,571 visitors online*
Results 1 to 4 of 4
    Dec 2009
    75
    power disconnect
    Hello,
    What do most shops do as far as shutting off power to their cnc machines.
    1: Just shut of the machine at the control.
    2: After shutting down at the control, kill power at the machines built in disconnect on the power cabinet.
    3: After shutting down at the control, kill power at a wall mounted or other disconnect not built into the machine.
    Currently we are been killing breakers at night to avoid potential lightning damage. We are moving machines to a new building and are going to install
    disconnect switches remote from the machines and not do this with the circuit breakers anymore.
    Just asking for opinions.
    Murph
    Jul 2005
    12177
    I suppose it depends on how many machines you have but a big disconnect ahead of the breaker panel means you can isolate averything with a single switch throw.
    Mar 2010
    1852
    I use the machine disconnects. Be sure to properly ground your machines too.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Dec 2008
    717
    Quote Originally Posted by murphdog View Post
    Shutting off Power....? Hmmmm...I don't follow:drowning:
    Tim
  1. 416 X-axis disconnect alarm
    By alexbelen7 in forum Fanuc
    Last Post: 09-21-2013, 10:20 AM
  2. y axis disconnect on a O-M controller
    By kirby in forum Fanuc
    Last Post: 08-09-2013, 07:22 PM
  3. Need disconnect for powerfeed
    By Chevy-SS in forum Benchtop Machines
    Last Post: 04-09-2007, 04:27 PM
  4. sizing main disconnect
    By 69owb in forum CNC Machine Related Electronics
    Last Post: 04-01-2006, 11:00 PM
  5. how do I disconnect microswitch?
    By jeremyinnys in forum CNC Machine Related Electronics
    Last Post: 10-12-2005, 04:40 PM
