587,569 active members*
3,710 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Posting of G18 or G19 commands
Results 1 to 5 of 5
    Apr 2013
    0
    Question Posting of G18 or G19 commands
    OK well to start I'm new on here, but anyway when im posting out my program to do an arc in the XZ or YZ axis it won't post out the G18 or G19 command .I have tried different posts , tried the arc filter but it still keeps giving me the point to point on the arc resulting in a "faceted" looking part, Which isn't good . Since we are using ver5.2 and not on maintenence anymore they (Surfcam) won't even let me get past the receptionist, unless we get back on maintenence. what do i need to edit in the post to have it post out the G18/G19 commands?
    The easiest way to do is to have 3 ddifferent post, one for each plane, G17, G18, and G18
    Just get to your Postform.m, copy the entire post you're using for your machine and paste it twice bellow the former, name it diferently, for instance "name FANUC G17" / * G18 / and * G19.
    Then you must edit the last 2 posts; at the 1stToolChange find the line that reads something like "G<40> G<90> G<17> G<Work> X<H> Y<V> " and replace the G<17> by G<18>, making sure change every G<17> statement; and then proceed with the G19 post.
    When you run a job with arcs in XZ or YZ plane, post it with the related post.
    This procedure is also needed when the job is done in a machine that can orientate the spindle at diferent planes. I mentioned "Fanuc", but it's the same for any machine you may have.
    Hope have been clear enough, have doubts?, just ask.
    Mario
    Apr 2013
    0
    Mario that might work if i was doing just the one direction , but the part i was working on had both G18 and G19 moves ,which i ended up programming by hand . for future jobs like this i would like to have a post which would output the correct commands ,thanks for the input though.
    I believe you’re just trying to get the impossible. Let me try to explain:
    When in SURFCAM, and want to NC 2 axis contour a radius in ZX axis, you MUST change the settings to Cview = <2> ( or Cview = <3>) and Coord = View. Is it Ok?
    To work in YZ axis it’ll be Cview = <5> or <6>. All the same happens if you want to use drilling / tapping cycles. As a matter of facts, you can work in any plane (angle / CView) you might have created.
    In any of this cases, SURFCAM lets you machine in any side of a part without moving it, just change your settings. But regardless the settings your *.inc output WILL ALWAYS BE the spindle being the Z axis.
    Now take this to the Mpost, and it doesn’t have any function to recognize Cview plane. And here comes why you need 3 different posts (or more), one for each working plane. In it, the trick is to swap the axis, according to the worked plane.
    They’re very useful in machines with swivel heads, or equipped with right angle attachments.
    Now if what you want is to contour an arc in XZ plane using a ball end mill in a VMC, ( as cutting a grove) then you have to - "Create / Spline / Elements "- using that Arc, and cut it with "Contour 3D". This way post it in regular manner, because your Inc is output in very small segments of G01; no need to post G18/19.
    The other option is having a 5 axis machine, but then in SURFCAM, under NC 5 axis, there is no G2/G3 function.
    Should you have any doubt, just ask.
    Mario.
    May 2012
    100
    If you are using Mpost, make sure that you have
    this in your post:
    ArcPlane g 17 18 19
    CtrCode I J K
    And in toolchange, in some systems G17 must be present for
    the Lcomp to be in Z direction, before G43 H code so
    add G<ArcPlane> in toolchange and 1st toolchange.
    Example:
    ToolChange
    G40 G21 G17
    M5
    M6 T<Tool>
    G94 G90 G54 S<Speed> M<Direct>
    G<0> X<H> Y<V>
    G<43> Z<D> H<Tool>
    G<ArcPlane>
    end
    This works great when i use arcfilter for posting, you also can add
    a ArcCode sequence in the processor.
  1. problem posting MCX5 posting to Cimco edit v5.6
    By cdmmachining in forum Mastercam
    Last Post: 05-10-2012, 02:09 PM
  2. Why are there F1.0 commands in my code?
    By SWATH in forum Rhinocam
    Last Post: 12-05-2011, 05:40 PM
  3. Dos Commands
    By LYN BYRD in forum Milltronics
    Last Post: 08-01-2011, 04:21 PM
  4. G2 and G3 Commands
    By Bohemund in forum G-Code Programing
    Last Post: 05-28-2007, 03:12 PM
  5. Difference between BL and SV commands?
    By Shizzlemah in forum Fadal
    Last Post: 03-23-2007, 02:33 PM
