I have BC V24..purchased back in '11.
I had everything up and running reasonably well.
I run BC on my laptop then transfer the files to my old pc with xp to run Mach 3 via a usb thumb drive.
At some point my laptop crashed and a new hard drive was installed. I downloaded BC and the same post processor I believe I have been using all along.
The g code output is definitely different with the newer post processor. I downloaded all of the pp pertaining to mach and none of them output the same as
the old one. Needless to say I have to modify all g code to make it work after I post it. I have to open it up in notepad and remove lines and add a few, depending
on the operation. Somethings it just won't do. I have been limping along. I mostly make 3 d molds and modifying the code is easy. But pocketing, drilling and other multiple step
operations require too much work to rewrite. So maybe I have it all wrong?? I included an old bbcd file that I had the working g code for. The original g code (floot.tap) loads and runs fine in my mach3. The newer .tap file (floot1.tap) is generated from a newer pp with the same name as the pp used to generate the old file (floot.tap). You can see the difference
right away. The new stuff just doesn't work in mach for me. Mach settings? Some sorta parameter issue....Just bite the bullet and pay BC again for a working pp?
Thanks for your time.
Vince
