587,560 active members*
3,479 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > post processor for mach3 (lathe for wood legs)
Page 1 of 2 12
Results 1 to 20 of 33
    Feb 2022
    59
    hi everyone
    I am building a lathe for wood legs , and i want to work with mach3 and powermill
    but i have a little problem , concerning the post processor ,
    or if anyone can suggest another software to generate toolpath...
    if anyone can help
    thanks in advance
    Jun 2014
    20
    Re: post processor for mach3 (lathe for wood legs)
    Without being too costly have you thought about fusion360.
    I have quite a few milling machine posts but never had for a lathe I'm afraid.
    Could you not utilise one of the template posts powermill comes with?
    Sent from my SM-F711B using Tapatalk
    Everyday is a school day.
    Feb 2022
    59
    thanks for your reply
    in fact it not a lathe , it a cnc router with a 4th axis , ( x,y,z,a) , i thinks if we say 4 axis that mean all axis should move in the same time
    Feb 2022
    59
    for the software , the reason that i say powermill is i have done somme research and it seems that they talk about powermill (youtube ...), is it work in fusion 360 it very helpfull for me ,
    Jun 2014
    20
    Fusion will have its own mach3 post which will work no problem. And I use both fusion and powermill and if I had to start my own shop I would hands down use fusion. Its cheaper. Can grow with the needs you have and bu the sound of what you want it for powermill maybe overkill
    Jun 2014
    20
    I use grbl post in fusion 360 and it works fine. You can even tweak the mach3 post to be capable of using 4th axis. There will be tonnes of info online on how to do that.
    Feb 2022
    59
    but does fusion 360 capable of generating tolpath for 3d legs ( wood legs)?
    Feb 2022
    59
    Quote Originally Posted by nodgedeeeeeeee View Post
    https://www.youtube.com/watch?v=ESnJtDIeJRM&t=162s
    this links show an example of what i want to do ,does fusion 360 can do like this , i have not a lot of experience ,
    Jun 2014
    20
    Yes fusion 360 is exceptional
    Jun 2014
    20
    But you are going to have to work hard on your post processor doing exactly what you want it too. But with fusion the online presence is huge so it's a good place to start I think.
    Feb 2022
    59
    i have another question , does powermill can generate 4th axis toolpath if the software is cracked?
    Jun 2014
    20
    Yes it should do. I used to have cracked version of 2016 and that would have worked but after I upgraded to Windows 10 no longer worked.
    As long as you have ductpost installed and a post processor it should work fine.
    Feb 2022
    59
    ok , thanks i will install it first , then see what can i do with the post processor
    can you please guide me or suggest any source that provide a postprocessor for mach 3 (4 axis cnc ) ,
    thanks
    Jun 2014
    20
    I would look on the powermill forum which is now adopted by autodesk. There will certainly be people who have had the same questions etc as you. If not create a question yourself and one of the gurus will help or point you in the right direction. They will try to prompt you to purchase a post as they should do but as you are using cracked software I would keep that quiet for obvious reasons.
    This is why I said about using fusion as its free to download and when you are ready to purchase the software properly (once you are using it for monetary gain) it doesn't cost the earth and is fully legit.
    Nov 2013
    4537
    I use Fusion 360 and have done for several years, the basic subscription is about $550USD/year. Its very useful and I use it daily for work.
    Basic Fusion can do three axis stuff and three axis plus indexing fourth axis, but it cannot do continuous coordinated (simultaneous) fourth axis, and therefore would NOT think it suitable
    for table legs.
    Last year I bought and introductory offer of Fusion Machining Extensions, the intro offer was $1200USD/year verses the full cost of $1600USD/year. Machining Extensions
    now gives you genuine simultaneous four and five axis tool paths, and would be highly suitable for table legs. There are two toolpath options, Rotary Pocket and Rotary Contour,
    that will appeal to you in a big way.
    So I believe Fusion is and would be very good for your purpose but not cheap. You need the basic subscription ($550/year) and Machining Extensions ($1600/year) for a total
    $2150/year. You may think that exorbitant but when you compare it to other CAM software that can do simultaneous five axis it's not, and is in fact quite cheap. The bottom line
    is that simultaneous five axis is eye-wateringly expensive. Whether there are better value simultaneous four axis CAM solutions is more than I can say, most probably there are.
    I wanted simultaneous five axis and Fusion is bang for you buck the best I could get. My subscription is due in about another three months, I will definetly being renewing the basic
    subscription, I use it daily to make a living, but it's unclear whether I can afford to renew Machining Extensions, I hope so....its just I don't know where the money is going to
    come from!
    Craig
    Feb 2022
    59
    Quote Originally Posted by joeavaerage View Post
    for table legs.
    come from!
    Craig
    hi craig
    for now i want to start without paying anything , i was thinking about powermill , and i have also done some research , i see everyone working with cracked powermill , and they modify the postprocessor , (but they don't provide it for free expect this russian guy)
    i found this russian guy that write or modify this script , can you tell is this is right and is it 4 th axis index or simultaneous 4 axis and if this will work for me
    my work is anly 3d wood legs ,
    thanks you
    Feb 2022
    59
    Quote Originally Posted by Diae View Post
    hi craig
    thanks you
    https://www.youtube.com/watch?v=WZlxmCBLgt0
    Jun 2014
    20
    Yes this looks right except you don't have the baxis so the post will need tweaking to not use that axis. The rest seems fine.
    Feb 2022
    59
    the b axis ? do you mean the last part of video when he show a 5 axis machine?
    i thinks the postprocessor that he wrote is for 4 axis ,
    Nov 2013
    4537
    I don't know what the policy is on pirate software here on the forum, but it does not reflect well on you personally. That some 'Russian Guy' has cracked PowerMill
    is par for the course and may well describe some the disdain that many hold the Russians in.
    Craig
Page 1 of 2 12
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. Replies: 0
    Last Post: 04-25-2020, 04:04 AM
  3. post processor for cnc router cutting wood Bobcad V26.
    By racer6 in forum BobCad Post Processors
    Last Post: 08-25-2017, 08:04 PM
  4. Which Post Processor to use with BobCAD V24 Lathe and Mach3?
    By NICKKINSMAN in forum BobCad Post Processors
    Last Post: 04-18-2014, 04:10 PM
  5. Post Processor for Mach3 Lathe Question
    By BrassBuilder in forum Dolphin CAD/CAM
    Last Post: 11-09-2011, 11:38 PM
