Hi, I need a pp. (EdgeCam) for my machine. I live in Norway and the dealer says that a pp. cost 20.000 NOK, ca. 4000 USD.
My machine is a two axes CNC lathe (1997).
Best regards,
Frøya :-)
Best regards,
Frøya :-)
Hello Froya,
Old Edgecam posts are not capable of
using all the new functions of the software.
You need a newer "adaptive" post.
I recommend you open the Code Wizard
- Start New Document
- Lathe
- 2 Axis
- Load default Parametric Graphics
- select template - adaptive moriseiki.cgt
- Machine Setup Tab
Edit the dimensions / travels / number of stations / etc.
to match your machine.
If your SL-15 is the (old) Yasnac control
- Code Generator Tab
- NC Style, G-Codes & Modality
- NC File General
- Reverse X Axis
Open an Edgecam .ppf file - Generate code.
leave the Editor open.
Test your new post - in the Code Wizard
use the "Re-Run" button, this will regenerate
the same code using the new post,
every time you change something in the Code Wizard
Re-Run the output to see the changes in the NC code.
There is no UNDO button in the Code Wizard,
If you break it - you must manually undo your last change
While I was geting started with the wizzard (had worked a lot with the old compiler) I lerned the hard way to make a sub dir to put copys of my cgd files in (before any large change)
Ernie
