587,603 active members*
3,716 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Possible to 'frost' (diffuse) clear acrylic with a rock tumbler?
Results 1 to 6 of 6
    Jul 2008
    139
    I'd to be able change totally clear transparent acrylic so that its outer skin is 'frosted' ...this is so light from LEDs inside the acrylic is diffused.
    I'm only talking small parts (a couple of inches)...do you think a rock tumbler grit/sand combination might work?
    Jul 2003
    28
    How about sandblasting or applying frosted mylar.
    Jul 2006
    1062
    Quote Originally Posted by lsalme View Post
    +1 here...seems quicker cheaper and simpler.
    Keith
    Mar 2009
    70
    Quote Originally Posted by HankMcSpank View Post
    How about a chemical solution? Something you could wipe on, then wipe off?
    :cheers:Ted
    If you are going to be a Bear... then be a Grizzly!
    Sep 2008
    68
    Your best route is probably to use a stock frosted sheet from the Perspex or Plexiglas range. Most UK suppliers have frost in the racks ready to go.
    Plexiglas do a stock clear which is frosted on one side only- most other frost sheets have a frost finish on both sides.
    If you want to make your own frost effect you have two options. Firstly you can cover clear acrylic in standard frosted vinyl (as used by the sign trade). Second, you can shot blast clear acrylic to create a frost effect. This works quite well but takes practice to get an even frost effect.
    As for LED illumination...... frosted acrylic works quite well but for a diffused light effect an Opal White acrylic might be a better option. Opal 050 is the standard grade used on most large illuminated signs. You can also buy other grades; 030, 070 etc.
    The Opal numbers refer to light transmission- i.e 050 lets 50% of the light through the acrylic sheet whilst 030 only lets through 30%
    Sep 2003
    1113
    Check these samples...
    600 grit sandpaper? Acetone? Just a couple of quick ideas. But the tumbler idea might work - but would get all surfaces, including the edges.
    Had a minute - I had to do a quick check to verify.
    Plain acrylic (unknown specifics--a scrap).
    Left side (2 x2 squares) milky appearence from acetone. Looked difficult to control the finish and density of the frosting. Fairly smooth finish, however.
    Right side (2x2) squares 240 grit sandpapper. Easy to control amount of frost -- but finish will pick up grit and dirt through time. Could do on inside to prevent that.
    Center is paint thinner - -- sorry no laquer thinner to try.
    Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. Hello, I is Dumb as a Rock...
    By Bambi in forum Community Club House
    Last Post: 03-11-2009, 12:04 AM
  2. 50mm thick Acrylic Clear offcuts
    By didja_do in forum Australia, New Zealand Club House
    Last Post: 02-17-2009, 08:26 AM
  3. Gecko's rock
    By PoolQ in forum Gecko Drives
    Last Post: 05-06-2008, 01:19 AM
  4. Alibre's Tutorials ROCK
    By Rance in forum Uncategorised CAD Discussion
    Last Post: 07-20-2006, 05:39 AM
  5. Clear Acrylic Fender Stratocaster Guitar
    By HygloCompany in forum Glass, Plastic and Stone
    Last Post: 02-17-2006, 06:49 PM
