587,480 active members*
3,493 visitors online*
Results 1 to 2 of 2
    Jul 2005
    12
    PMDX-122 and PMDX-411
    I recently 4 Stepperonline kits including: 4 1699oz. Closed loops motors with CL86Y drivers. I am using a PMDX-411 for my controller. It is attached to my PMDX-122 Breakout board. I am using Mach4 software (purchased hobby version). I am running individual power supplies for each motor and driver and a 5 volt power supply for the PMDX-122.
    This is my third build and my largest. I have never used closed loop before, but with its accuracy and resolution, I thought it a good idea.
    Here is my problem. I have hooked the four motors to the drivers and to the terminals on the BOB as X,Y,Z,A. In Mach4 I am slaving A with X. Two motors for the X Axis.
    When I turn the system on and try jogging, everything works well except for Z. Z will spin one direction, but will create a fault when trying to spin the other direction.
    Now if I remove lets say the A drive, everything works fine. I have tested every possible combinations, using different motors with different drivers etc. All with the same results.
    Has anyone had any issue with this, I have contacted both Stepperonline and PMDX people, but I do not believe they are working through this pandemic.
    Any help would be greatly appreciated!
    Daryl
    Sep 2005
    1740
    Re: PMDX-122 and PMDX-411
    What I learned you can not have a A motor as Slave to your X. Your motors are setup with Motor 0, Motor 1 and so on and then assigned to the axis. Take A motor out all together. Then whatever motor # you want as a Slave to the X motor number add that as Slave. You still have the 4 motors, only one is a slave. I am using direct drive screws, if I was using belt drive to rack and pinon the Slaved side might need reversed, just a Click in the setup screen. No big deal.
    Your Z problem might go away after all this, if not check the wiring.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  1. Replies: 1
    Last Post: 12-14-2016, 03:10 AM
  2. PMDX 126 VS 122
    By pryotex in forum CNC Machine Related Electronics
    Last Post: 10-03-2015, 10:23 PM
  3. Replies: 0
    Last Post: 02-26-2014, 03:41 AM
  4. Having Issues w/ PMDX-126 PMDX-134 and Ethernet Smooth Stepper
    By Hurshy in forum Community Club House
    Last Post: 08-27-2013, 01:20 PM
  5. PMDX-125 or PMDX-132 for Geckos?
    By Nivea in forum Gecko Drives
    Last Post: 03-24-2010, 08:18 AM
