587,136 active members*
3,665 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, a few questions about file read / write
Results 1 to 10 of 10
    Jun 2015
    4156
    hello pls, what is the difference between FOPENA and FOPENB ?
    also, why is there an "A" : FWRITC coords.txt;A ? kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Aug 2011
    420
    Re: pls, a few questions about file read / write
    The FOPENA and FOPENB commands allow you to "open" 2 different files at the same time to GET data from.
    FOPENA and FOPENB commands for reading data only
    "Imagination is more important than knowledge."
    Jun 2015
    4156
    hey, thx kurmay that image makes sense : it seems that is possible to have active simultaneously 2 buffers for reading + only one for writing
    i was looking for double buffering when writing, not when reading
    i just discovered that these 2 work : FWRITC file-name.txt;A and FWRITC file-name.txt;C, but i have no clue what's the difference between A & C
    also, in that image, instead of " read file a , read file b , read file c ", should be " read file a , read file b , write file c " or " file a opened , file b opened , file c opened "
    a file can be opened for both "write" or "read" actions
    thx again ...
    Aug 2011
    420
    FWRITC_device-name:file-name.extension;A
    ;A is option function : Specifies the Append mode
    Jun 2015
    4156
    that info is not in my lathe manuals
    pls, what are the append modes ? can you share more infos ?
    aaa, i just found something into the mill manuals ... again, the lathe team vs mill team
    Aug 2011
    420
    Mill team is more sharing data than lathe team
    Jun 2015
    4156
    yeah .. however, in the manual is nothing more about the ;A, besides what you shared ... i still have no clue about FWRITC file-name.txt; + "nothing" or "A" or "C"
    maybe is not that important Azerbaijan ? not bad ...
    Jun 2015
    4156
    comparing to a linear code, using a single read-buffer ( only fopena ) will lead to an execution time +10%; using 2 read-buffers ( fopena&fopenb ) will hit into +17%
    thus is better to concatenate data into a single file, or just create a linear code
    i think that these functions are from a period when okuma tried to move over the dnc, by putting the source data file into the controller, so to speed up the data transfer
    absolute difference, for the code tested, between linear and fopen* codes was arround 0.04-0.06 seconds/block, is not much, but it sums up if the code is longer
    i mess with such values, because i have an operation log, from which i extract data about operation duration and day-moment of execution
    i try to keep the load on the system as minimal as possible : for example i load data into the buffer until i almost fill it up, and only after that i write it to the file : this reduces the "data write" events : a "write" event may occure after several operations ( eq after 1.5 cycles ), and when it writes down, it writes data about all the operations that had passed
    is a way to create a machinig log for series, with minimal cycle downtime / kindly
    Jun 2015
    4156
    Quote Originally Posted by deadlykitten View Post
    hello past self of my self
    fwritc requires an append mode :
    ... A : data is added to the file, thus allready existing content is preserved; this mode is ok for log-files
    ... C : data is rewriten to the file, thus allready existing content is gone; this mode is ok for single-sessions, for example shopping-lists : now, you have to buy this, and you can trash away the shoping-list from previous week
    of course, if something has to be added to the list, while you are shopping, then append A mode is required : honey, you should have bought all those junks + cat food; why did you bought only the cat food ? what will we eat now ? your mind is always at that hungry pu55y cat ... duuh / got it ?
    C mode is there to avoid increasing the file size, especially when data from previous session is no longer required / kindly
    Jun 2015
    4156
    hello please, any idea why next program does not work on osp200 ? it seems it can't read a negative value / kindly
    Code:
        V1 = -123.456
        FWRITC abcdef.txt;C
        PUT V1 , 9
        WRITE C
        CLOSE C
        FOPENA abcdef.txt
        READ A
        GET V2 , 9
        CLOSE A
    M02
  1. Read Write Protection
    By scurr in forum SIEMENS -> GENERAL
    Last Post: 06-02-2016, 10:52 AM
  2. how to read dxf file ?
    By deadlykitten in forum Okuma
    Last Post: 01-11-2016, 04:18 PM
  3. Are there any commands to write a .txt/.tap file from a Gcode?
    By FuriousGeorge in forum Tormach PathPilot™
    Last Post: 08-16-2015, 01:22 AM
  4. Is it possible to write file that is stored in USB?
    By Stephan Spears in forum Okuma
    Last Post: 05-06-2015, 01:55 PM
  5. write to file possible ?
    By mcgpz1 in forum Parametric Programing
    Last Post: 06-12-2008, 04:41 PM
