587,172 active members*
3,248 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > please tell me what is best stepper motor for my cnc router
Results 1 to 7 of 7
    Dec 2006
    1
    Exclamation please tell me what is best stepper motor for my cnc router
    hello every body
    im trying to build my own cnc router machine
    so please tell me what is the bset stepper motor i can use for my cnc router ?
    + my machine dimension will be about 160 * 100
    + i will use my router for cut wood and mybe for glass too
    May 2003
    325
    read steppers and servos at http://cnczone.com/forums/showthread.php?t=17419
    bigger is better; if you pick small motors you must make very shallow cuts at slow
    speeds that take a very long time.
    robotic regards,
    Tom
    "I can write better than anybody
    who can write faster, and I can
    write faster than anybody who
    can write better."
    - - A. J. Liebling
    Feb 2012
    0
    Someone can recommend us some stepper motor model for a 1,60 * 1,00 machine?
    Thanks!!
    Mar 2009
    533
    check this out.
    Stepper Motor
    Feb 2012
    0
    160CMX100cm????
    Feb 2012
    0
    Thanks KOC62! (Y)...
    Yes David, 160cmX100cm. I need to make a prototype of a laser cutter for a textile company.
    Thanks in advance for your help.
    Feb 2012
    0
    I have a size 160X90cm dimension laser cutting machine(I think the size is just like your machine) and i also used for cutting textile ,the efficiency is good.and we use three phase stepper motor, the Model is 24HC3301-05,because i am chinese ,so the stepper model made in china,the price is about 55$ for export ,if you need ,i can help you connact with the factory,
  1. use satellite dish actuator motor as a stepper motor
    By ozni in forum Stepper Motors / Drives
    Last Post: 06-19-2010, 01:55 AM
  2. Motor tunning settings for 4'x4' router,plasma stepper setup.
    By rncole in forum Waterjet General Topics
    Last Post: 04-26-2008, 06:11 AM
  3. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
  4. CNC Router and it's stepper!
    By watzmann in forum Community Club House
    Last Post: 10-09-2005, 05:49 PM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors / Drives
    Last Post: 01-04-2005, 12:05 AM
