hello, i need to generate a cutting edge ...
edge is simple, a 60degree triangle, 1 mm height ... after that i copy - paste to obtain rest of the teeth
how is it possible to change base dimensions, and all teeth to autoupdate ? so to obtain fast all teeth for 60degree*2mm height, or 45degrees*1mm height ? kindly !
