587,256 active members*
2,878 visitors online*
Results 1 to 15 of 15
    Jun 2017
    369
    Please Help which double sided tape?
    Im new to CNC routers and while I'd like to eventually get a vacuum table right now I need a way to hold down the small pieces. Tabs just aren't always the answer & I went to the local hardware store and purchased some carpet tape but I have a couple issues with it.
    If I'm doing detailed cuts I'd need to cover the entire area with tape and that can get expensive, and it has a tendency to gum up the bit. Sometimes it is really hard to get the tape off.
    Does anyone have any tape they have purchased in bulk that is a little cheaper even if it's from Amazon or eBay?
    Has anyone used transfer tape / pre-masking tape from the sign industry on the bottom of the job then doubleside tape to that?
    Thanks in advance
    Gary
    35538
    Re: Please Help which double sided tape?
    A trick that a lot of people use is to put blue tape on both the part, and the table, and super glue them together. It works much better than double sided tape.
    I use golf club grip tape, which is a two sided masking tape.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2017
    369
    What is the price difference between carpet tape & golf club tape?
    What glue are they using?
    The best two sided tape for holding parts in a CNC is "SCOTCH 3M 401M"
    It's as thin as masking tape, but has adhesive on both sides!
    Sells for $29.99 /36-yards x 1" wide, on Amazon
    Jan 2007
    96
    I have tried 2 brands of carpet tape, which hold well, but if you don't remove it quickly, it tends to come off in small pieces. Some of the tape I've tried from HD was grippy but was really stretchy and broke apart when I tried to peel it off.
    I'm sorry, I just have a tough time buying $30. rolls of tape but using that stuff is sweet.. 3M's stuff is reliably high quality product, but they also know it. I'm going to try ger's super glue tape combo. Forgot about that one.
    What I don't like about Carpet tape is its spongy and too thick! In order to hold a 12" square piece of wood, it must be perfectly flat and requires long pieces of tape to get a stable piece to machine at higher feed rates!
    With the 3M tape, I use a 1"x1" piece in each corner, and put a 2nd or 3rd piece on top of one to make it flat! Then I hammer it down to the machine top, and carve away! Note, none of the tapes will work on MDF, so I usually put an aluminum or plastic spoil plate on the table first!
    So $30 = 432 1"squares, or 100+ parts @ $.39/part
    Attached Thumbnails Attached Thumbnails FullSizeRender (1).jpg   FullSizeRender.jpg
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Jul 2007
    1602
    I often use Scotch Adhesive Transfer Tape. It is really thin, most grades are around 1.5 mil, It is usually applied with a gun but can be applied from the roll if you are careful. It is used a lot by paper crafters, picture framers and artists so can be easily be found in stores that cater to them. It retails for about $10 a roll but you can get easily find it online for around $6. I would suggest trying a roll and if you like it, getting the gun (Scotch ATG 700).
    bob
    Mar 2008
    683
    Shure-Tape DF 65 is smooth
    Shure-Tape GG 200 is crepe paper
    Only problem is they sell it by the box at about 13 bucks a roll. Best stuff I've ever used. And it doesn't leave any gummy residue.
    Dec 2005
    600
    Quote Originally Posted by warrenb View Post
    Warren,
    Where do you get the Shure-Tape? Sounds like something I could use.
    Mark
    Jun 2017
    369
    Thanks, I found 3 rolls on eBay of the DF65 for $14 a roll but at least I didn't have to buy a case.
    Thanks again
    Mar 2008
    683
    I buy it direct from Shurtape. I don't know if there are retail outlets for their products.
    Dec 2005
    600
    Thanks Warren. I'll check them out.
    Mark
    Jun 2017
    369
    I got mine in the mail yesterday & tried it out last night & it worked great thanks
    Nov 2014
    724
    Amazon has Shurtape DF-65 for about $11/roll, and Spectape ST501 for about $15/roll, if you're Prime they're both free shipping. I still have a good supply of the double stick tape my local laser shop guys gave me so I've never used the Shurtape or Spectape but they both look like they'll work pretty good.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Jan 2004
    3154
    I use the mitee grip tape that requires a heat gun to get it to come off
    www.integratedmechanical.ca
  1. Double sided tape for warped wood
    By taverner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-07-2011, 07:48 PM
  2. Double sided carpet tape
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 08-18-2010, 03:01 PM
  3. Double Sided Hold Down Tape's
    By KustomKoncepts in forum Commercial CNC Wood Routers
    Last Post: 03-13-2008, 03:14 PM
  4. Double sided tape
    By Greolt in forum CNC Tooling
    Last Post: 09-17-2007, 10:11 PM
  5. Double Sided Tape? Really?
    By kentavv in forum MetalWork Discussion
    Last Post: 12-03-2006, 05:47 PM
