Hi All,
We have milltronics rh-30 with centurion 6 controller, and we want to transfer larger program in dnc mode with rs-232 cable, we made cable and setting same as milltronics service says, and we use nc link program as sender, but when we click to send from to pc then F10-UTIL, F6-DNC, F3 FAST then RS-232 but machine show on the screen WAITING FOR DNC LINK, all of thing is look like ok but what is the problem why we can not use that? anyone has any idea to help me??
Also same machine has 7,5 KW yaskawa motor and VS-626 M5 yaskawa inverter,
Our problem is spindle does not has any power to cut soft material or drill small hole, spindle is stopping while we cut the cast material nearly 0,5 mm and after this we need to shut down the cnc and then open again, in fact we dont understand why our machine spindle is not powerful, ı think so its because of parameter, or another ? please help me if anyone has any idea,,
Thank you......
