587,506 active members*
3,186 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Picking a Driver for a Stepper 3.1 amps
    Feb 2011
    0
    Would this Probotix driver work for my steppers.
    Probotix Driver
    Bi-Polar Stepper Motor Microstepping Chopper Driver
    Chopper Current Driver
    .5-2.5 Amp Current Limiting
    Dual H-Bridge Configuration
    Full, 1/2, 1/4, & 8th Microstepping Resolution
    8V - 32V Supply
    The Stepper specs
    Powermax
    P22NRXC-LNN-NS-00:
    Torque: 238
    Resistance parallel: 0.78
    Current parallel: 3.1
    V: 2.418
    Watts: ~7.254
    Inductance parallel: 3.1mH
    Mar 2012
    0
    Probotix: Great Value
    We have recently finished my first build. We purchased no plans and did only the minimal of research. Then I met Len & Jeremy from Probotix and they helped us quickly develop a specification, sources and ultimately the build and tuning of our machine. I owe them a huge plug and debt of gratitude because they went way above and beyond what I would have expected in regards to service, mentor-ship and support for the project. Also I special thanks to Ahren from CNC Router Parts who produced and sold us a custom frame kit.
    Our machine is Powered by Probitix and for the most part has been supported by them too. Although financially most of the build came from other sources Probitix by far was most able and willing to support our project. THANKS A MILLION!
    Machine Spec:
    Work Area: Z=8" X=60" Y=48"
    Custom Mechanical Kit: Similar to CRP4848
    link: CRP4848 4' x 4' CNC Router Kit | CNCRouterParts
    why: Len recommended it
    Spindle: Hitachi M12VC Router
    Link: [ame=http://www.amazon.com/dp/B0002ZZWXI/?tag=hyprod-20&hvadid=15470184459&hvpos=1o1&hvexid=&hvnetw=g&h vrand=1878145930462139526&hvpone=&hvptwo=&hvqmt=&r ef=asc_df_B0002ZZWXI]Hitachi M12VC 2-1/4-Horsepower Variable-Speed Router - Amazon.com[/ame]
    why: It is the only router that supports a 1/2 cutter and also work with a Precise Bits collet system
    Collet: BOUP-1618-842KIT from Precise Bits
    link:Precision Bosch 1600 Compatible Nuts and Collets
    why: Improved Z and run out accuracy. Also to be able to hold a larger range of cutter than the stock Hitachi collet could hold
    Dust Control Shroud: KentCNC Standard dust shoe
    Link: KentCNC, LLC. Standard Dust Shoe
    Why: it was well reviewed by CNCRP
    Powered By Probotix:
    Electronics Steppers/Steppers: Nema23/ 4 Axis Monster
    Link: 4-Axis Monster CNC Stepper Motor Driver Kit - 4-Axis Monster CNC Stepper Motor Driver Kit
    Ready to Run 40VDC Linear RTR Controller: Probotix (Similar to their Comet controller)
    Link: http://www.probotix.com/image/enclosure_back.jpg
    CPU: Ubuntu/EMC2 Control Computer (EMC2PC)/ Keyboard, Mouse, Monitor, & Joypad (KMMJ)
    Supplied, Set up & Configured by Probotix which was an amazing help both at the time of purchase and when we where ready to get things running
    Estop & Limit Switched Heavy Duty Limit Switch (LS2) & Custom Limit switch Brackets (Ask Len to make these a standard product )
    Link: Emergency E-stop Switches and Limit Switches
    Switch bracket blocks: Someone should ask Len to make these a standard product becuase they are awesome
    Dust Collector:
    SHOP FOX W1685 1.5-Horsepower 1,280 CFM Dust Collector
    PLUG:
    Buy from Probotix because they are willing to responsibly supply and support their products. Do it yourself does not mean “you are on your own” when working with Probotix. Not only are they great with support but they actually seem to enjoy talking to and helping their customers. I have had no issues when any of their parts. The controller is working very well and they provided Plug and play quality service to us. I would also add that all the venders we purchased from where really great!
    Apr 2008
    13
    thanks for the detailed writeup jonas, that was quite helpful to me.
  1. Help picking replacement stepper driver board
    By herring_fish in forum Hobby Discussion
    Last Post: 02-15-2012, 04:55 AM
  2. RMS versus Peak Amps - Stepper Driver
    By kochevnik in forum CNC Machine Related Electronics
    Last Post: 10-17-2006, 02:06 PM
  3. Picking out a Driver bd-newbie ???
    By lemonyx in forum CNC Machine Related Electronics
    Last Post: 04-03-2006, 07:43 PM
  4. Picking a Gecko Stepper Driver?
    By pfeist in forum Gecko Drives
    Last Post: 09-29-2005, 05:04 PM
  5. Help picking a Driver
    By met4life in forum Stepper Motors / Drives
    Last Post: 03-23-2005, 12:43 AM
