587,436 active members*
3,728 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > PDB air "leak" from the control valve?
Results 1 to 12 of 12
    Jul 2017
    5
    Wondering if anyone else has a constant air "flow" audible from their PDB control valve? We've checked all of the fittings on the outside in and out, and the needle valves, etc. This "leak" or "flow" seems to be originating from inside the valve box. It's not like the tiny leaks that you'll sometimes hear from a compressed air fitting but a fuller high flow type sound. Definitely enough flow to require the compressor to come on more frequently than every 30 minutes or so it usually cycles at.
    We have regulated 90psi service to the valve and the PDB is functioning normally otherwise.
    Is this normal??
    Feb 2006
    7063
    Re: PDB air "leak" from the control valve?
    No, its not normal, but also not unusual for solenoid pneumatic valves. You can CAREFULLY disassemble the valve (there are springs and other small parts inside, and orientation of several parts is critical), removing the "shuttle", which has several O-rings on it. Slather some silicone grease (available at any auto parts store) on the o-rings, and re-assemble. If that does not fix it, you can try replacing the o-rings, though they may be an oddball metric size.
    Regards,
    Ray L.
    Jun 2012
    311
    After 5 years of use my PDB control assembly has developed a leak similar to what you're describing. I have not attempted to diagnose or repair it yet. Compressor with a 20 gallon tank cycles about every 30 minutes or so also. Kind of annoying.
    Jul 2017
    5
    Thanks for the replies!
    This one is brand new out of the box from Tormach so we'll let them know for QC and then I think we'll attempt to disassemble and grease it as SCzEngrgGroup suggested. I'll post back here with results.
    May 2016
    138
    If its brand new, i'd get it replaced before opening it up and voiding any warranty it might have.
    Jun 2006
    3063
    Tormach does sell a seal kit for the power drawbar air cylinder:
    https://www.tormach.com/store/index....show&ref=32093
    and NYCNC did a YouTube video on rebuilding the 1100 power drawbar.
    https://www.youtube.com/watch?v=gkE0vk_oDAU
    Dec 2003
    673
    Quote Originally Posted by GreenLightGo View Post
    Is this normal??
    Not normal, I had that too. Tormach replaced it and the new one was fine. I used to build pneumatic systems commercially, and that happens more than you would think with new parts.
    Jun 2014
    1780
    Quote Originally Posted by Spinnetti View Post
    Mine has leaked air since new, a bit over 5 years ago, I thought it was the cylinder orings, never checked it out. Maybe just a new control valve is all thats needed?
    mike sr
    Jun 2006
    3063
    Mine started leaking air a year or two after I first installed and I'd been running it "dry" since that's what the manual instructed. Tormach tech support told me that they had been misinformed by the air cylinder manufacturer and that they now recommended running the PDB with "oiled" air so I installed one of the FRL kits from Tormach and re-built the cylinder with their seal kit. I've had no leaks since then. FWIW, the old seals did look a bit worn.
    Jun 2012
    311
    Michael,
    Did you replace the seals in the PDB cylinder or the control valve?
    Jun 2006
    3063
    Quote Originally Posted by IMT View Post
    Michael,
    Just the cylinder seals. I haven't had a problem with the control valve yet.
    i have recently got a leak on my powerdraw bar, and like the original poster said, its a big leak that seams to be coming from the button valve area. i got a replacemtn push button valve from tormach for $20 and replaced it. that didnt fix the problem though, and has lead me to do some more digging. although the air "leak seams to be coming from the button area, i believe whats actually happening is the large drawbar cycliner is binding/ not closing properly and leaving that air line open. im gonna take the cylinder apart tonight while wathcing the nycnc video. gonna see if i can get away with a clean and lube, but will order a rebuild kit if any damage is seen.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Replies: 2
    Last Post: 06-14-2013, 12:50 AM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Control will "punch" but not "read"
    By dansteinmetz in forum Fanuc
    Last Post: 04-06-2010, 10:10 PM
  5. "Fixing" bent engine valve?
    By mmmjboner in forum Bending, Forging, Extrusion...
    Last Post: 07-16-2007, 09:40 PM
