587,421 active members*
3,318 visitors online*
Results 1 to 5 of 5
    Oct 2011
    477
    PDB - Air Cylinders
    I am looking for the source of the Pancake type cylinders used on the Tormach Power Draw Bar. I would like to add one or two stages to the existing three stage PDB thereby increasing the force available at the drawbar and adding a couple of nested Bellville springs to significantly increase the clamping force.
    Any idea of where these come from?
    gary
    Apr 2013
    1788
    Re: PDB - Air Cylinders
    Take a look at the thread at https://www.cnczone.com/forums/torma...2-tormach.html
    Please keep us informed of your progress on this project.
    Oct 2011
    477
    Sure does look similar!
    Great lead, thanks!
    gary
    Jun 2006
    3063
    This may have been in the other thread, but mine is labeled "XINYIPC CQ2100X12-3"
    Google finds this for that search term:
    CQ2100 X 12-3
    Automation Direct sells a 100mm x 15mm single for $119. Not sure with shipping and the new tariffs that it might be cheaper to get a set from them. Link:"Automation Direct"
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
  1. LF Quote for 2 Cylinders
    By TheDukeAnumber1 in forum North America RFQ's
    Last Post: 11-20-2012, 09:55 PM
  2. best way to control 25 air cylinders?
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 01-17-2010, 12:04 PM
  3. grooved steel cylinders
    By threeninethree in forum Employment Opportunity
    Last Post: 11-16-2009, 02:45 PM
  4. Need to control 40 to 60 cylinders... ugh
    By SuperBob in forum CNC Machine Related Electronics
    Last Post: 03-29-2009, 09:05 PM
  5. Air cylinders, PSI & Force they have ???
    By Chris D in forum Mechanical Calculations/Engineering Design
    Last Post: 05-01-2006, 05:23 AM
