Thanks! Your Bug Report/Feature Request has been received.
Comments: PathPilot ‘COLLET’ open/close safety interlock function. I believe PP tries to prevent the collet from being opened anytime the spindle is rotating however the logic in v1.9.8, …, v1.9.11 seems faulty and allows you run the spindle regardless if it’s closed or open. The only time an error message is generated is if the spindle is rotating while the collect is opened and you then press the button to close it. This message states “Cannot open collet while spindle is on” This is in contrast to the fact we are already running the spindle with the collet opened. The logic should follow something along these lines:
Whenever the spindle is command to rotate, either through the “CYLCE START” or manual operation, the collet must be closed or the appropriate error message is generated & the spindle does not rotate.
At anytime the spindle is rotating the trying to open the collet generates the appropriate warning message and the collect remains closed.
