Hello everyone,
Firstly thanks for reading this if you do and if you try to help out I'd like to thank you now as well.
Anyway the question i have is i am using a tool setter to set my z axis every time I change the tool which is great but when the g-code has done it's thing and the machine continues to the next cut is where I find my little issue of the Path Plot being out from my Back plot, but while I'm at it, it also affects my soft limits of my z axis so I've had to make my machine "bigger than it is" in the config file.
Just wondering if anyone could point me in the right direction of how to keep the Path and Back polt on the same "Level" and how to stop LinuxCNC thinking my machine is to small when i use the g-code routines to set Z/Tool height when changing tools in a program.
Hope this all makes cents and that someone out there might be able to help/in lighten me. If anyone else needs more info to try and help please just ask and I will reply with what I can.
Cheers
William
