I'd like to get quoted for the 3 different parts I have. Drawings are attached in ACAD 2000i DWG format.
All parts:
-6061 AL
-all tolerences to +-.01, but holes/slot tolerence should be -0.000 +.01.
-Deburred edges
-raw finish
-Shipping prepaid by myself both ways.
Part 1:
This is an aluminum disc 1/2 thick with a 3/8 hole through the middle and a 5/8 rounded slot on top (with a ballnose endmill or equiv). I will be providing the materials, and the circular shape is already made as it is just cut from 3" dia 6061 bar stock to 1/2 thicknesses.
All the machining that needs to be done is that rounded slot, and the 3/8 hole in the middle.
Part 2:
Rectanglar part. Using 1"x1" barstock, all I need is the holes and threads machined. The 1"x1" need not be machined in fact, and the length cut to 1.5" can be cut with a band saw and finish left raw.
Part 3:
rectanglar part
once again using 1"x1" barstock, all i need is the holes and threads machine. Facets of the barstock need not be machined and the length of 2.25 cut from barstock can be left raw.
Please quote all parts per item cost with 20,50,100 parts being made in one production run (i.e say 50 parts made, 5 dollars each, 250 dollars total for 50).
Thanks!
~Anthony
