587,375 active members*
3,123 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Parts needed for CNC Router 6.6ft x 10ft 3 axis. Also optional big Z axis.
Results 1 to 2 of 2
    Jun 2014
    5
    Hello,
    I am going to finish a CNC machine that my father started more than 10 years ago, because now I want to use it to make moulds for fibreglass or carbon-fibre for full-scale race kitcars and some minor aluminium parts needed for the cars and ocassional woodworking for our main business. As fas as I know if I make the machine with bigger Z axis I will have problems with harder materials but I hope it shouldn't be a problem since I will use the full Z axis lenght only on softer materials like polyurethane with very slow feedrate just for the moulds and I want to make a moveable table to place it closer to the gantry (10-15 cm) for harder materials like aluminium or when the extra Z is not needed.
    So far I have these parts that are on the pictures: tooth racks and the aluminium guides. Which other parts would I need? My mechanic told me to use stepper motors as they are cheaper and would do the work but I would like to hear your oppinions. He told me to look for NEMA34 1232oz/in. There are also 1600oz/in ... will they work better? What about servo motors? What size and spec would I need? Are there more affordable ones?
    Greetings from Bulgaria,
    Peter
    Attachment 240864Attachment 240866Attachment 240868
    Jun 2014
    5
    Re: Parts needed for CNC Router 6.6ft x 10ft 3 axis. Also optional big Z axis.
    Hello,
    Does anyone have idea what specification servo motors do I need in first place to start searching?
    Thank you in advance,
    Peter
  1. Z axis build using CNC Router Parts.
    By niner_zero in forum Avid CNC
    Last Post: 09-15-2013, 03:49 PM
  2. 3 axis cnc router based on supported rails conception design and parts
    By pierantoine in forum DIY CNC Router Table Machines
    Last Post: 05-15-2013, 10:11 PM
  3. MDF Parts Needed Good Quantities 5 AXIS Router(??)
    By chuckerjones in forum North America RFQ's
    Last Post: 12-20-2012, 10:29 PM
  4. Locating Large Non-Square Parts on a Five Axis CNC Router
    By Mexellent in forum MetalWork Discussion
    Last Post: 02-04-2008, 06:24 PM
  5. Full 4th axis optional?
    By chuy in forum Fanuc
    Last Post: 11-09-2007, 06:26 PM
