587,436 active members*
3,682 visitors online*
IndustryArena Forum > CAM Software > Esprit > Parking the lower turret
Results 1 to 4 of 4
    Apr 2003
    1357
    I'm wondering what the best way is to get the lower turret out of the way for a pick-up to the sub-spindle. I tried to use the park command, and I can get the lower turret to move out of the way, but it just jumps back to the center. How can I get it to stay put? I'm not using it for anything in this case, whether that's a factor or not I don't know.
    Thanks in advance for any tips.
    Dan
    Jun 2010
    81
    Does the code look good when the lower turret moves out of the way? It could be the home position in the machine define setup is not correct.
    Apr 2003
    1357
    Problem solved. I needed to define an empty tool in the lower turret and make sure the tool change position equaled "none".
    Thanks,
    Dan
    Jan 2012
    59
    thats right it needs a dummy tool
  1. Macturn: Tool change during lower turret move
    By Green Button in forum Okuma
    Last Post: 12-20-2010, 07:37 AM
  2. Hardinge Superslant SB3 GN 3 Axis Lower Turret
    By LMartin in forum Hardinge Lathes
    Last Post: 09-17-2010, 03:42 PM
  3. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
  4. parking problems
    By N.V.M. in forum CNC Machining Centers
    Last Post: 07-27-2007, 05:04 AM
  5. Lower turret won't feed
    By bvaught in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 12:46 AM
