587,446 active members*
3,245 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Parked steel wheels are flat spotted?
    Feb 2006
    12
    Hi, I have a presentation to do for the refurbishment work I've been doing.
    I need to discuss the flat spots that are present on the steel wheels that are being refurbished. These weren't worn, these look like they have just been dented flat by gravity.
    They may have been static for as much as five years but probably less, they have 40 years service, that wear is evident and obvious but not bad, however the flat spots are perfectly smooth.
    I can't find the correct terms to describe this. Any help?
    Mar 2006
    2712
    Re: Parked steel wheels are flat spotted?
    How many wheels; what are they attached to; were they attached to shafts in pairs (like on overhead hoists?); must they be refurbed to equal dia.'s or to a prescribed dia.?
    Dick Z
    DZASTR
    Dec 2003
    24219
    I doubt if it from being stationary, most likely they were skidded over a period due to lack of traction etc, same thing happens to train car wheels when these are braked.
    They not only get flat, but get a burn spot where the contact point melts!!.
    Al.
    Albert E.
  1. just flat steel signs
    By navy80to04 in forum Signmaking Topics
    Last Post: 02-23-2014, 05:40 PM
  2. Mild steel flat work
    By kdoney in forum North America RFQ's
    Last Post: 10-16-2013, 10:43 PM
  3. RFQ flat spring steel parts - laser or edm
    By amv101 in forum RFQ (Request for Quote)
    Last Post: 03-27-2012, 03:16 AM
  4. Replies: 6
    Last Post: 05-09-2011, 06:13 PM
  5. Machining Steel Tubing Flat
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 03-16-2008, 11:55 PM
