587,872 active members*
4,094 visitors online*
Results 1 to 5 of 5
    Dec 2009
    972
    Parameters for FANUC 0-TT
    hello
    i have a TAKISAWA TM15 lathe with FANUC 0-TT and i lost all parameters.
    i have the parameters but i dont know how to write down because at start-up appears on the screen onlt THND ,no EDIT MODE so i can not put in the parameters.
    Does anyone know what should i press at start-up to have the EDIT MODE active or is any procedure?
    PLEASE HELP!!!!!!!
    Maybe is a combination of keys for FANUC 0-TT for write the paraeters.
    Try firing them in with the E-Stop in.
    The Fanuc Support Center Team
    www.fanuc-support.com
    Dec 2003
    24220
    Do you have the PWE bit set =1 and in MDI?
    If you PM me an email add I can send you the Fanuc bulletin.
    Hopefully you have the 900 parameters, some have to be initially loaded by hand in order for RS232 loading.
    Al.
    Albert E.
    Dec 2009
    972
    yeah solve it.
    i push the emg key but was not working so i took it out and made the conection between .
    10x for help
    GOOOD LUCK!
    Sep 2009
    68
    Re: Parameters for FANUC 0-TT
    Hi Zavateandu,
    Are you willing to share the parameters for the lathe Takisawa TM15?
    thank you very much in advance.
  1. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  2. fanuc 11m parameters
    By sootblower in forum Fanuc
    Last Post: 08-11-2018, 08:30 AM
  3. Fanuc parameters
    By Mehboob ur Rehm in forum Fanuc
    Last Post: 02-28-2012, 09:54 AM
  4. Fanuc 3T Parameters
    By vsmvj in forum CNC Swiss Screw Machines
    Last Post: 10-20-2010, 08:22 PM
  5. Parameters Fanuc 6M
    By Olsson in forum Fanuc
    Last Post: 12-26-2009, 03:07 PM
