587,833 active members*
3,387 visitors online*
Results 1 to 4 of 4
    Dec 2006
    310
    Overcurrent Detector
    Dear All
    V have got a controller which generates overcurrent alarm
    We need to know which IC monitors current in the loop and generates overcurrent alarm
    This PCB has got following ICs viz SN75173N, 75172N, 75C188,9829,75C189A,TDKT ZJYS4
    Will it be possible to tell which of the above ICs is to monitor current and generate error in case of overcurrent as v need to locate that IC and replace because physical conditions r ok and no error comes after replacing PCB with new one that means overcurrent detector is only faulty
    Regards,
    M. Rishikesh
    Dec 2003
    24220
    What controller?
    I assume you mean a servo drive of some sort?
    If so the over current usually comes internally from current detection in the drive output components.
    There is also a case where the main controller indicates the fault and this could receive a digital input from a drive O.C. output in order to register a readable alarm on a screen.
    Al.
    Albert E.
    Dec 2006
    310
    Sir
    Actually it is a CNC Controller not Servo (Sorry i did not mention it earlier)
    Will it be possible for u to tell if any of these ICs viz SN75173N, 75172N, 75C188,9829,75C189A,TDKT ZJYS4 actually detect current and may be they have gone bad, due to which we are getting detect error although physical conditions r not as such because just after replacing this CNC PCB with OK one, we r thro with the problem
    Regards,
    M. Rishikesh
    Dec 2003
    24220
    If it is the controller giving the alarm then I would assume it is getting it from a drive or? if so what I would attempt first is to try and find out/trace the input into the controller and reverse engineer from there by tracing back to which IC is receiving the input?
    Al.
    Albert E.
  1. Linistepper Overcurrent Sensor
    By Yachaan in forum Open Source Controller Boards
    Last Post: 08-20-2012, 08:47 PM
  2. alarm 161 x-axis overcurrent
    By eksinger in forum Haas Mills
    Last Post: 12-15-2010, 01:17 PM
  3. axis overcurrent
    By lovell110 in forum Haas Mills
    Last Post: 08-15-2007, 06:03 PM
  4. VF-2 overcurrent on Y axis
    By coalstove in forum Haas Mills
    Last Post: 08-03-2006, 08:32 PM
  5. alarm! spindle overcurrent
    By jianjianca in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2006, 04:35 AM
