587,529 active members*
3,544 visitors online*
Thread: Out of Range
Results 1 to 6 of 6
    Dec 2006
    310
    Out of Range
    Dear All
    We have got a CPU with Windows 2000 Professional
    We are able to go to Set up Mode and able to see all the related screens but during normal power up, without going to Set up Mode, we get Out Of Range 43.2KHz/85Hz or Input Not Supported
    As per message on screen, if we press F8 to get into Advanced Mode, it is not getting into Advanced Mode so that we can try to change resolution
    Kindly advice
    Regards,
    M. Rishikesh
    Mar 2010
    115
    Try starting the pc in safe mode. That will force it into 640*480 mode at a low refresh rate.
    It sounds like you've just exceeded the rating of your monitor.
    Dec 2006
    310
    Sir
    Thanks for ur quick response
    Pl refer to our thread, v r unable to get into advanced mode by pressing F8
    Kindly advice
    Regards,
    M. Rishikesh
    Mar 2010
    115
    I said safe mode. That's what it's called. Wasn't sure what you were talking about.
    Are you using a keyboard with "special" F keys? Look for an "F Lock" key.
    Problem with those, is that when the pc is first booted up, the F keys aren't F keys yet! You have to very quickly hit the F lock button, then start hitting F8.
    Oct 2009
    78
    M.RISHIKESH,
    Continuously tap the F8 key while the computer is booting up. First a window will pop up that requires you to choose the drive. The drive is IDE-0 on most PCs. Select the drive that has your operating system installed and then continue to tap the F8 key. Windows will start in the Safe Mode.
    RFB
    Jun 2009
    135
    Attach another monitor that can run that fast and then slow the refresh rate.
  1. Pay range
    By pgf545 in forum PTC Pro/Manufacture
    Last Post: 02-08-2013, 03:26 PM
  2. High, Low Range
    By Technical Ted in forum Mastercam
    Last Post: 05-14-2011, 04:39 PM
  3. ATC-Out of range HELP
    By Hardblackxx in forum Fadal
    Last Post: 06-10-2009, 04:21 PM
  4. Arc Voltage Range
    By Big John T in forum Waterjet General Topics
    Last Post: 03-17-2008, 02:44 PM
  5. Mid-range first CNC
    By iXô in forum Open Source CNC Machine Designs
    Last Post: 09-19-2007, 02:42 AM
