if necessary reinstall the software, you must purchase install software (probably one diskette) and its price is about 1000€ (only one or two file your recommended)
Can I backup all the software in the CNC to Foppy disk ? And can I use re-install it? If I can buy the software Bin.BBM and MEU.MPB
Plaese sent to me email.
Thank you
This files are special every machine. You can't backup all software CNC to Floppy disk.
Can I buy the sofware correct number of the machine ? And Where I buy?
Thank you.
You can buy from local okuma dealer
Since the machine works good, You better don't mess with software.
If You need full backup, You must crack the Okuma CPU. It could be Motorola 6800 for such an old machine if you are lucky. Normally the mission impossible, there is an Okuma CPU used.
Okuma doesn't support such an old machines anymore. Pricing for software, electronics is high. You take care of it, keep it clean. You check the contactors, relays and connectors in a regular base and this machine will serve You long years.
You can backup all parameters, all user data, all tool data, all settings. This is very advised to do in a regular basis.
Hello Algirdas,
Can you instruction for me full backup the software? I think the board duobble memory error I need the sofware re-install it.
If have not software I don't know it how repair.
Please you see the pictures.
Please send to me Email.
My email: [email protected]
Thank you
Hello Kurmay.
Thank you very much for your help.
If you have the software, please send to me.
Thank you.
