Is it possible for this control to change the working plane so that XY would actually become YZ, because it would be very easy to use an aggregate/angle head this way? If yes, what are the parameters or settings needed to be changed?
Coordinate rotation is what you are after, you will need to check the spec sheet to see if you have it
