587,636 active members*
3,479 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP-P200L-R / OSP-P200LA-R
Results 1 to 5 of 5
    Sep 2012
    0
    HELLO, everybody i need to learn the sequence to touch off the tools in an OKUMA GENOS L300E-M with a OSP-P200L-R it has a probe arm for doing so and if you can tell me if i can do it the old fashion( cutting the OD or ID and measuring and inputting the dimension, like in FANUC you have the option of doing it with or with out the probe arm)or not, also is there any difference between the OSP-P200L-R and the OSP-P200LA-R controls for lathe, regarding setting up the machine? i have been working in FANUC controls for 10 years and only worked with old okumas for a couple of months, like 5 years ago the ones withe green screen probably built in mid or late 90's and they are fairly easy to learn but now in this new job this controls look totally different.thankyou very much for your help, i appreciate any input you guys have a great day.
    Jun 2008
    372
    A series are generally the 5 axis controllers
    Apr 2009
    1262
    You should still be able to do it the old fashioned way. Just use the CAL key and enter the known value your tool is at in X or Z.
    I think all of the P200's will work the same for setting up tools.
    Best regards,
    Apr 2006
    825
    Have a look at this post I put up some time ago.
    http://www.cnczone.com/forums/1174147-post6.html
    Hopefully this will put you on the right track.
    Regards
    Brian
    Mar 2009
    1982
    is your touch setter manual or maybe fully automatic (NC)?
    if touch setter is manual; what happens if you do so:
    1. interlock release (pressed operator stress button) with door open
    2. manual mode
    3. open touch setter to it's active position
    Previous controls automatically show tool offset screen with active tool X offset highlighted.
    If this control do the same or not?
  1. Okuma OSP-P200L parts counter
    By rtM396 in forum Okuma
    Last Post: 04-30-2018, 03:51 PM
  2. Hard Drive failure on OSP-P200L
    By gunrights in forum Okuma
    Last Post: 06-15-2012, 10:10 PM
  3. Okuma OSP-P200L Programing
    By trampus in forum Okuma
    Last Post: 11-19-2010, 04:35 PM
  4. OSP-P200L want to read z offset
    By 1noodle in forum Okuma
    Last Post: 10-22-2010, 04:56 PM
  5. Angle head Okuma VTM-120Yb OSP-P200L
    By ProToZyKo in forum Okuma
    Last Post: 06-27-2010, 08:13 PM
