587,453 active members*
4,408 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Options for using a CAT 40 Tool Holder
Results 1 to 5 of 5
    Mar 2015
    11
    I'm in the process of designing a CNC mill, and I want my machine to use CAT 40 tool holders. My main question is what are my options for mounting a tool holder with a cat 40 taper to some combination of motor / spindle available as a standalone or universal part. I want it to be fairly powerful for cutting both wood and metal, but I also want it to be as precise as possible.
    Was thinking about using a suitable motor to drive the tool shaft via a belt and pulley system, with the shaft and motor both mounted to a thick bracket side-by-side, something like this:
    Metal Bracket (Motor ===> Pulley ===> Shaft ===>) ===> Cat 40 Drawbar (?) ===> Tool Holder ===> Cutting Tool
    The problem I'm running into is a serious lack of information about the part that sits between the motor and the tool holder, which seems to be called the drawbar. I even tried finding some kind of retro-fitting options that I could cobble together and make work for my application but no dice. I don't need the drawbar to support automated tool changing for now and it doesn't need to be pneumatic, but something with a quick manual release would be nice.
    35538
    Re: Options for using a CAT 40 Tool Holder
    The part between the motor and toolholder is the spindle. A CAT40 spindle will be quite expensive, and is way overkill for cutting wood.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2015
    11
    If it wasn't overkill it wouldn't be worth doing.
    Is there any store you can recommend that I check out for spindles? Any recommendations on which brands to consider?
    35538
    No. I have no experience with CAT40 spindles, but I'd guess that they would be upwards of $10,000.
    Gerry
    Oct 2013
    62
    15.000 usd for a 12.000 rpm spindle. The guys from HIGH SPEED do a lot of repair and they will certainly get you a good spindle at a fair price 5.000 to 10.000
  1. Vertical lathe tool holder for Tormach Tool System.
    By TXFred in forum News Announcements
    Last Post: 08-18-2014, 09:20 AM
  2. Replies: 10
    Last Post: 11-06-2012, 11:43 PM
  3. Tool Breakage Detection options
    By dak1 in forum Uncategorised MetalWorking Machines
    Last Post: 10-12-2012, 03:28 PM
  4. Replies: 2
    Last Post: 11-05-2011, 11:42 PM
  5. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 11:04 AM
